You can use MTK Droid Tools to root many Mediatek (MTK) chipset based phones and tablets, make backups, create scatter.txt file or change IMEI number(s) of your phone. You can also change build prop of your device to be able to download previously incompatible apps and games from Google Play Store. It can do some other things as well.
You need to install MTK USB driver if not already installed. You can follow the procedure here. You also need to enable USB debugging options from Settings > Developer options menu.
Run the program and then connect your phone. It will recognize your device and give related information on it’s screen.
[ATTACHMENT NOT FOUND]
Download MTK Droid Tools here:
[hide]MTK Droid Tools version 2.4.5[/hide]
