I have a doogee dg500 will not turn ,charge ect. any ideas
Take out the battery and measure the voltage with a multimeter. Do you read a voltage above 3 volts?
[hr] yes 3.8v
if you can boot into recovery mode, you can try a factory reset.
[hr] will not boot anything
Is it recognized by SP flash tool? (after installing the correct USB drivers). If it is, then find a ROM for your phone and install it.
Thank you phone working with splash tool and factory rom no wifi am going to try old rom
phone working no wifi or bluetooth just stays turning on wifi or bluetooth any ideas
