MP3 Cutter and Ringtone Maker
Cut audio and make ringtones using best MP3 Cutter app. and save it as your best music, ringtone, alarm, or notification tone.
If you love music and song an want to cut it use this MP3 Cutter and Ringtone Maker free app.
Best Ringtone Maker tool help you to make mp3 ringtones in easy and convenient way, just select audio and set start and end point of song to cut it.
MP3 Cutter can trim the best part of your favorite song with accuracy for free.
Why are you waiting? Make the new clips and set it as your default ringtone or assign ringtone to contacts, using this free ringtone editor.
Ringtone cutter helps more, one who love music and want to set different tones for each contacts in phone.
So ,if you have good collection of song and you want to cut it, just use this app and select best part from that and save it to your sdcard.
Features Highlights of MP3 Cutter and Ringtone Maker app.:
– Create unlimited Ringtone / Alarm / Notification Tone of custom lengths you want
– Supports most popular audio formats like MP3, M4A, WAV, AMR, AAC etc.
– Easy to select start and end point of song
– Record new music and use it with ringtone maker to cut it if you like.
– Millisecond-level perfect cut.
– Easy interface for select best part of audio with touch.
– Manually set the start and end time by entering the values in input box.
– Use any name of audio during save.
– Set the new song as default or assign it to contacts, using this free ringtone editor.
How to Use? Just select MP3 / music from your device. Select area to be cropped from the audio file and then save it with name of your choice in your mobile.
Application Supports MP3, WAV, AAC, AMR and most other music/audio formats
Link to Download: https://play.google.com/store/apps/details?id=com.creative.mp3cutter.audiocutter
[IMG]https://lh3.googleusercontent.com/uGq0J-1r59RTPTeIu8iAiE-Xq7LkFcahqLoFGhD8q47C1G_qykYxObR0V6Rd4RB0fSc=h900[/IMG] [IMG]https://lh3.googleusercontent.com/JM59ta7Z4B2Qp2O19MmNqD1I1dKbglUWGg7P9LJtmaK9XGMqAc7GsKPjkfpY4lHfcQ=h310[/IMG]
