MLais MX59, 5 inch Android smartphone with quad-core chipset
  • #4333
    MLais MX59
    MLais is preapring their new smartphone lineup, those phone is MLais MX59 that packs with 5 inch screen size with 1080p screen display and quad-core 1.5GHz processor.
    MLais MX59 is packs with nice design, comparing with the recent products (MLais MX58), the new MX59 has beter specs than a predecessor.
    MLais MX59 powered by Mediatek MTK6589 quad-core 1.5GHz processor, MT6589 Tubro is currently MediaTek highest standard four core smartphone chip, compared to the MT6589 performance has greatly improved, with 1GB of RAM and 16 GB of ROM this phone is also support for up to 64G memory card expansion.
    The MX59 screen is packs with 5-inch 1080P IPS screen, and uses OGS full fitting process, with better light transmission and display, and the surface as well Corning Gorilla Glass protection. The MLais MX59 has 13 megapixel fron facing camera with wide-angle and self-timer capacbility,
    In addition, it will be the standard 2,800 mA battery, running with Android 4.2 version of the operating system that supports WCDMA + GSM dual card dual standby, built-in gyroscope, light, distance and gravity sensors and other commonly used, and also equipped with LED light. This phone is offers for only 1,299 yuan or around $212 USD price tag per unit.
