Meizu Releases Flyme 5.1.5 Stable ROM: Adds VoLTE to Pro 5 Flagship
- This topic has 0 replies, 1 voice, and was last updated 10 years, 6 months ago by
April 27, 2016 at 10:10 AM #10563
MemberMeizu has just releasedthe new Flyme 5.1.5.0 Stable release for a number of devices like the Meizu MX5, MX5e, PRo 5, MX4 Pro, MX4, M2 Note, M2, M1 Note and Meizu Metal. So, that’s a lot of devices getting the new Flyme version. While there are some notable upgrades available to many devices in this new version, the biggest benefit will be for the Pro 5 flagship. This new Flyme version will add VoLTE support for the flagship model which enables high definition voice and video calls.
Other features added by this version include browser support for flash to play videos, ad blocking, Wi-Fi network diagnostics, slide to camera from lock screen, power consumption manager and a lot more as mentioned in the change log below.
One thing to note here is that while upgrading the Meizu MX4 model, you might not be able to see the progress on the screen. However, on the background the update will be running. Hence, once you start the upgrade, don’t restart or downgrade until the process is completely finished. You can check out all the details, including the download links from down below.
Download links:
5 PRO: http://www.flyme.cn/firmwarelist-23.html
MX5 / MX5 Classic: http://www.flyme.cn/firmwarelist-18.html
PRO MX4: http://www.flyme.cn/firmwarelist-7.html
MX4: http://www.flyme.cn/firmwarelist-6.html
Blue Charm Metal: http://www.flyme.cn/firmwarelist-24.html
Charm Blue Note: http://www.flyme.cn/firmwarelist-8.html
2 Charm Blue Note: http://www.flyme.cn/firmwarelist-10.html
Charm Blue 2: http://www.flyme.cn/firmwarelist-19.html
Update log | Communication
– Optimization: Update PRO 5 Baseband version
– VoLTE: PRO 5 to increase the support for VoLTE
Update Log | System Upgrade
– Improve the system upgrade mode: Added “experience receiving firmware version” switch ( Click for details )
– Fixed: notification bar even now click “download updates” no response
Update Log | Free flow pass fast
– Free flow pass fast: optimized file sharing experience, increase visualization page
Update log | Desktop
– Desktop editing: adding mobile support under Utility mode icons and widget
– Optimization: prompt desktop editing position adjustment
Update log | WLAN
– Network speed: new network speed function, a key to view the current network speed
– Network Diagnostics: new network diagnostic function, a key to detect the current network status
– Entrance: Settings – Wi-Fi – Click on the currently connected hotspot enters details page
– Fix: After a Wi-Fi switch to the data network will pop up authentication information
Update log | browser
– Intro: increased functionality for the first time to launch a new intro
– Ad blocking: browser settings increase the “ad blocking” switch
– Flash: Support Flash Player mainstream video site
Update log | install external applications
– Optimization: Depending on the installation source and application versions to distinguish between different installation scenarios, detailed display application permissions and chargeback risk
– Optimization: Increase downgrade installations processing
– Optimization: Tips why the installation failed
Update log | voice assistant
– Optimization: Optimizing Home Recommended to avoid screen flicker when loading data
– Optimization: Optimization of alarm to remind user experience, allows you to view all the alarm and turn off all alarm
Update log | lock screen
– Optimization: lock screen camera is called the left slide to slide
Update log | Audio
– Fix: listening to music with headphones, the notification bar switch mute any friction or break the sound
– Fixed: When headphones to listen to music, to micro-channel message or phone, listen to the micro-channel voice, the sound suddenly becomes large
Update log | Mobile housekeeper
– Fixed: notification bar displays information flow switch failure problem
Update Log | Application Encryption
– Fix: micro-channel phone book can be read encrypted messages
Update log | camera
– Fixed: third-party applications do not call the camera OK button and remake after shooting
– Fix: under password lock screen shortcut to open the camera when using the camera flash back Burst
Update log | Music
– Music Comments: Add Comments Reply to comment and thumbs up function
– Local Scan: add a key scan local music, support audio filter
– Folder Management: Add all folders management functions
– FM Radio: New FM radio
– Message Center: New Message Center, you can view comments and bulletins Reply
– Push Message: New “Receive message push” switch
– Manual reordering: playlist support manually adjust the playback sequence
– Version Upgrade: New version upgrade inlet
– Optimization: Optimization of musical support for Talkback
– Optimization: Adjustment template Home Sort, “I guess you like” Move to the fold
Update log | clock
– Online ringtones: set alarm tone increase “ringtone Online” portal
– World Clock: World clock when adding new cities by nationality search function
– Optimization: Merge Ringtones and Flyme music as “local music”
– Timer: timer increases the volume control function
Update log | Calculator
– Optimization: support slide switch mode calculation
Update log | input method
– Symbol: Increase math, special, number three categories of symbols keyboard
Update log | landscaping theme
– Cheap Font: Font support special events
Update log | Search
– Optimization: Click Search plug into the search page, hot words card pre-show
Update log | Toolbox
– Optimization: Optimization compass calibration experience
– Optimization: adjust the measurement scale of initialize
Update log | sweep the
– Adjustment: Remove the “sweep card” feature
– Uninstall: sweep the APP support is unloaded
Update log | Settings
– Optimization: Optimization of power consumption management statistics
Update Log | Download Manager
– Optimization: Reconstruction download interface, remove MD5 calculation function, start speed optimization
