Meizu MX4 Pro’s measurements are 146 x 78.5 x 8.2mm, uses Kirin 920 chipset, and ha
  • #7143
    Recently, Weibo user, @包子玩机 posted a picture revealing details about the MX4 Pro. According to the picture, the MX4 Pro’s measurements are 146 x 78.5 x 8.2mm, bigger than the MX4, but its thickness is 0.7mm and its weight is 140g.
    The Pro version sports a 5.5-inch 2560 x 1536 display screen and uses the 2GHz Kirin 920 octa-core chipset. It also has 3GB RAM and has 32/64/128GB ROM. No information about the battery has been revealed as of now. The MX4’s 20.7mp IMX220 camera was also replaced with a 16mp IMX240 one for the Pro edition. The camera also has an f/1.8 aperture and can take 25 photos per second.
    However, one problem with the photo is that this device is supposed to support China Telecom 2G and 3G but the Kirin 920 does not support China Telecom networks. Therefore, if the MX4 Pro does use the Kirin 920 and be China Telecom-supported, it must use a separate baseband chip.
    s_57955da36a1c4d5ea30d9f61995f95ec
