Meizu Light Smartwatch Launches on Taobao Crowdfunding Platform
Meizu has launched its smartwatch on Taobao’s crowdfunding platform. The watch which is called Meizu Light Smartwatch looks like a regular watch but has some functions your regular watch doesn’t have.
There’s no AMOLED screen nor Android Wear (or regular android) and neither will you be able to change watch faces like you can do on the Huawei Watch. Do you remember the Elephone W2 Smartwatch? That’s what Meizu’s new watch reminds me of.
The Meizu Light Smartwatch however has it’s own strong points such as its stylish design and 240 days of standby power which is pretty impressive. The watch comes in 5 varieties to match different occasions/activities. There’s one with a chain-strap that comes in gun metal black and silver colours; if you prefer leather, you can also pick one of two colour options, brown or black; and a final one that has a blue and white nylon strap.
Dimensions for the watch says it will have a 42 mm diameter dial and 12 mm thickness. The Meizu light smartwatch’s surface is protected by sapphire glass and features a 316L solid steel band and frame. The leather version has its straps made from Italian leather. There’s bluetooth 4.0, a three-axis gyroscope, an accelerometer (for measuring steps), magnetic sensor, and a 270 mAh battery built-in. It is also water resistant up to 99 ft/30 meters (3 ATM).
Pairing the watch to your phone should be pretty easy after downloading the app as long as your phone supports bluetooth 4.0 and above.
The watch is priced according to the straps. The unit with the nylon strap costs 999 Yuan ($150), the version with the leather strap costs 1299 Yuan ($196), and the one with the chain strap costs 1499 Yuan ($226).
If you want to purchase this watch, you should head to Taobao’s crowdfunding page and save yourself some cash as the price will definitely increase if you decide you want to wait for re-sellers.
