The LeTV One Pro was one of the big flagship smartphone releases last month along with the Huawei P8. Today, we get to take a look at newly released photos of the device and check out how it looks up close.
The LeTV One Pro was released just last April 14 at a launch event in China. The new flagship features a 5.5-inch 2K display with a screen resolution of 2048 x 1536 pixels giving it a pixel density of around 564ppi.
The front of the device is fairly simple with a flat glass panel with very narrow side bezels and relatively narrow top and bottom bezels as well. The bottom bezel of the One Pro does not feature capacitive touch Home and navigation buttons so it is simply left blank. On the other hand, the top features a light sensor, the device’s earpiece, and its 4-Ultrapixel front-facing camera.
The rear of the device features a curved edge design which looks very similar to the iPhone 6 Plus. The 13-megapixel Sony IMX214 rear camera is placed near upper middle of the rear panel with a dual LED flash right below it and an LeTV logo right below that.
The top of the device features a 3.5mm headphone or headset jack and an IR transmitter while the bottom of the device shows the device’s speakers and USB port. Finally, the sides of the One Pro show a mute/unmute slider and the volume rocker on the left-hand side similar to the iPhone 6 Plus and the power button and the SIM card tray on the right-hand side.
On the inside, the LeTV One Pro features a Qualcomm Snapdragon 810 processor, 4GB of RAM, 32 or 64GB of internal storage, and a 3,000mAh battery. The LeTV One Pro is now available for 2,499 Yuan.
