Leaked Huawei Nexus Case Hints at Rear Hump
  • #9130
    The Huawei Nexus is one of the most anticipated smartphones of the year as it is the first time Google has partnered with a Chinese manufacturer for its annual smartphone. The alleged design of the Huawei Nexus has been leaked numerous times already and today we have a bit of confirmation of one of its features.
    huawei-nexus-case-leak-01Leaked pictures of a silicon case designed for the Huawei Nexus may have confirmed some of the device’s design features that were seen in previously leaked pictures including its rear-mounted circular fingerprint sensor as well as the protruding area or hump on the upper rear of the device where its camera and LED flash are located. There’s also a little hole near the slope of the raised area although we aren’t sure what it’s for yet.
    The Huawei Nexus has previously been rumored to feature a large 5.7-inch display, the new version of the Snapdragon 810 processor which supposedly fixes the chip’s infamous heat issues, 3GB of RAM, and 64GB of internal storage.
    The Huawei Nexus is the larger of the two Nexus devices that are set to be released this year. The other and smaller Nexus device will be produced by LG which has previously done the 1st generation of the Nexus 5. Both Nexus devices will feature the stock version of Google’s upcoming Android 6.0 Marshmallow operating system.
    huawei-nexus-case-leak-02 huawei-nexus-case-leak-03 huawei-nexus-case-leak-04 huawei-nexus-case-leak-05
