Kinkoo 40Watt 6-Port High Speed USB Charger Review
  • #9700
    If you have several devices and you want to charge them all at once at the highest possible speed, multi-port USB charger is a solution for that. let’s take a look at the Kinkoo 6-port high speed usb charger.
    Kinkoo® 40Watt 6-Port High Speed USB Charger Review: VIDEO
    Kinkoo® 40Watt 6-Port High Speed USB Charger Review: UNBOXING
    IMG_5122 IMG_5126
    The device comes in a rather nice packaging for the USB hub. Everything’s packed neatly and the contents include the USB hub itself, instruction manuals and the power cable.
    Kinkoo® 40Watt 6-Port High Speed USB Charger Review: DESIGN and FEATURES
    IMG_5131
    Basically, what Kinkoo charger offers are 6 USB ports that have the combined power output of 8A or maximum 2.4A of output per port. That means that all your USB powered devices will charge very fast as the HUB is able to detect the max. charging speed of the device.
    Each port has a recommended device for the best charging speeds but basically you can use any port for any device. A nice blue LED light indicates when the USB hub is powered on.
    IMG_5136
    On the back side we have a power input port.
    IMG_5134
    As far as overall build quality it is made of glossy plastic and it does not scream premium but does not look of feel cheap either.
    IMG_5138
    My biggest complaint is that there is no silicone pad on the bottom of the charger, which makes it slippery on any surface you put it on.
    Kinkoo® 40Watt 6-Port High Speed USB Charger Review: CONCLUSIONS
    All in all, the Kinkoo 40 Watt 6-Port high speed USB charger is nothing we haven’t seen before but it serves its purpose very well.
    IMG_5140
    My test results suggest that each USB port is capable of delivering fast charging speeds and so far I didn’t have any issues with it.
    The glossy plastic construction looks okay but it attracts fingerprints and smudges easily. Well, at least it is not that visible on the white surface.
    IMG_5128
    Another shortcoming is that there is no silicone pad on the bottom and the lack of it makes the USB charger slide on the table, especially with lots of cables attached to it.
    All in all, the Kinkoo charger is a great product for $25 price tag, which works great but you have to consider a few flaws.
