Kingzone K2 Review
- This topic has 0 replies, 1 voice, and was last updated 10 years, 11 months ago by .
Nowadays, many Chinese phones have perfect combination of performance and elegance, such as Kingzone K2. Kingzone K2 is the successor of the previous model Kingzone K1 and it is of thickness 6.6 mm, double 2.5D glass Arc (no frame technology), Gorilla Glass 3, a R angle curve design and at last the body made of metal alloy and plastic. Moreover, the rear side of the phone is quite appealing as it consists of double-layer tempered glass which gives you a smooth feeling as jade and a crystal clear rear screen. The rear side of the phone is a very shiny, and somewhat sparkly appearance of the chassis. A fingerprint reader is located at the rear-center, too and the device is available in two colors: Black and White.
Kingzone K2, like other phones has a thin rectangular volume button on the right side and below it is a lock screen button and the circular shiny camera button is placed to take photos without touching the screen – long time press for snapshot, double click for video recording and triple click for torch. There’s a single slot on the left side and the slot consists of a single tray used for two nano SIMs and one Micro-SD card.
Kingzone K2 features a 5 inch Corning Gorilla Glass 3 screen by the resolution of 1920*1080 pixels and the display consists of LTPS(Low Temperature Poly-silicon), which is another awesome technology providing a pixel density up to 401 ppi and 16 Million colors so that you can operate your phone easily in the dark (indoor) and in the light (outdoor).
under the hood is a Android 5.1, 64-bit, Mediatek MT6753, Quad-Core processor clocked at a frequency of 1.5 GHz. Kingzone K2 is also powered with 3 GB RAM and provides graphics with a GPU known as Mali-T720. The device also has a Li-Ion 2600mAh, non removable battery. The front camera of the phone is a CMOS 8 megapixel camera with AF (Autofocus) while the rear one has a 13 Megapixel camera with Sony Exmor RS IMX214 sensor.
Kingzone K2 supports 4G-LTE network and a Dual SIM with Dual Standby, as well as the NFC (Near field communication), a set of protocols that enable electronic devices to establish radio communication with each other by touching the devices together, or bringing them into proximity to a distance of typically 10 cm or less. By this function, you can send massive amount of data within seconds without the use of Wifi Direct or Bluetooth. They have termed it as Hot Knot. Kingzone K2 is filled with an internal storage capacity of 16 GB and you may extend the memory by inserting a Micro-SD card (up to 64 GB); or you can also connect a USB through an OTG cable.
