Kingzone K1 Specs Review
- This topic has 0 replies, 1 voice, and was last updated 12 years, 3 months ago by
james1991.
June 30, 2014 at 10:38 AM #6364
james1991
MemberKingzone K1 Specs Review
The Kingzone K1 is a new chinese smartphone running the Android OS. This great new phone has an impressive range of specs and an even better price. You can get the Kingzone K1 for around 270 dollars.
[video=youtube]https://www.youtube.com/watch?feature=player_embedded&v=AyHqLW6VYD0[/video]
Read on for a quick review on the specifications of the Kingzone K1 Android smartphone.
At a Glance
The Kingzone K1 has some pretty impressive specifications. These include:
5.5 inch FHD LTPS OGS screen with 1920×1080 resolution
1.7GHz Octa Core Processor
2GB of RAM
16GB of storage
Android 4.3.9
Digital Compass, gesture control and wireless charging support
Google Play
14MP rear camera and 8MP front facing camera with digital zoom and 1080p video recording.[video=youtube]https://www.youtube.com/watch?feature=player_embedded&v=3ZFZq6xT3dQ[/video]
General
When it comes to overall specifications, the Kingzone K1 does pretty well. Octa-core processing keeps things speedy, and 2GB of RAM makes multitasking a breeze. The Android OS on this device runs smoothly and looks fantastic on the 5.5 inch screen. A HD resolution lets you see all your 14 megapixel shots in all their glory, while the front facing 8 megapixel camera makes for some clear selfie shots.Display
The display on the Kingzone K1 is excellent. With gorilla glass, its hard to crack this beauty. A 1920×1080 high definition resolution keeps things crisp and clear. Colours look good and aren’t washed out. The size of the screen is pretty good too. Phablet devices are becoming more and more popular, and the Kingzone does not disappoint. Its extra large 5.5inch screen is great for productivity on the go.[ATTACHMENT NOT FOUND]
Camera
One of the best parts about the Kingzone K1 is that the manufacturer did not skimp out on providing a quality front facing camera. A lot of Android devices feature a great rear camera, but fail to provide a decent front facing camera. The Kingzone provides both, with a 14 megapixel rear camera and a front facing 8 megapixel camera. The camera also features digital zoom and supports full HD video recording.[ATTACHMENT NOT FOUND]
Connectivity
The Kingzone has a variety of connectivity options. It features dual micro sim slots. This means you can use two phone numbers at the same time, and is a great option for those who run businesses and need to have a separate number for personal use. With dual sims, you won’t need two phones. The Kingzone K1 is 3G, so data downloads will be fast and reliable. Not to mention, bluetooth and wireless connectivity are also included. The Kingzone K1 features the latest bluetooth 4.0 technology. Other connectivity options include NFC and GPS, with a built in GPS chipset. NFC is a great feature that can be used for wireless payments and transmissions without the need for Wifi and GPS.Processor
The Kingzone K1 features an MTK6592 Octa Core processor running at 1.7GHz. As you can imagine, this makes for a speedy device. The Kingzone runs the Android OS seamlessly and is capable of running multiple apps at a time without lag. 2GB of RAM also helps to keep things nice and quick, giving the device great multitasking capabilities.Other Features
The Kingzone comes with a variety of extra features. The Kingzone supports wireless charging, so get ready to throw out all those annoying charging cables. Other extra features include a G sensor, light sensor, distance sensor, digital compass, micro USB, 3.5mm AUX and expandable memory.Battery Life
The Kingzone K1 has a great battery life, powered by a 2500mAh built in Li-on battery. This should provide you with about 150-200 hours of standby time.Dimensions
The Kingzone K1 is a nice sized phone. It is rather slim, at only 6.8mm in depth. The 5.5” screen is on the larger end of the spectrum, bringing up the overall size of the phone. But for those looking for a larger device, the Kingzone works well. It won’t feel too bulky, and the slimness of the device makes it rather appealing.Verdict and Price
Overall, this is a pretty nice Android device, especially for its price tag. You can get the Kingzone K1 for around 270 US dollars. It is available in white or black. You might also want to purchase a wireless charging case to take advantage of the K1’s wireless charging support.[ATTACHMENT NOT FOUND]
[FCT]11305-2[/FCT] -
