JXD gaming device unveiled with MediaTek chipset
  • #5051
    JXD-S5800
    JXD was unveiled their new Android smartphone aimed for gamers. This time, JXD as the one of company based in Hong Kong which is introduced JXD S5800 is the successor of previous similar devices , such JXD S5110b.
    This smartphone comes with a design similar to the PSP gaming console. Packs with 5-inch IPS display with a resolution of 960 x 540 pixels, this flanked by a controller that makes it easy to playing the games. On the inside, the Android gaming smartphone is equipped with a quad core processor form MediaTek MTK6582 supported by 1GB of RAM and 8GB of internal memory.
    Other specifications, this device running Android 4.2 Jelly Bean operating system. At the rear, there is a 5 megapixel camera and a 0.3MP front facing camera. In addition, there is a 3000 mAh battery capacity.
    Interestingly, this smartphone should also be used as a normal smartphone, either on the phone calling or send SMS. Unfortnately, JXD has not announced the price that they would peg for this smartphone.
