Jiayu G5 starting to hit market on mid-October with metal body design
  • #4587
    JiayuG5
    While for now, most smartphne products is pack with plastic and metal body, the plastic body is represent the low-end smartphone, while the meta body is identical with hig-end smartphone. And one of Chinese smartphone manufacturer, Jiayu is now ready to release the Jiayu G5, low-end smartphone with metal body design.
    For now we have an official information about the new Jiayu G5 smartphone price list. The phone is also ready to hit the market on mid-October, the price of each version are as follows: Standard Edition: Black 1199 yuan ($195 USD) / white 1249 yuan ($204 USD), the high version black color 1499 yuan ($245 USD) / white version 1549 yuan ($253 USD) price tag per unit.
    G5 with two versions of the distinction between high and low  memory size, high version is 2G RAM with 32 GB of ROM, while the low version is packs with 1GB RAM and 4GB of ROM. Both versions are using MTK6589T Quad processor / 4.5 inches 720P full screen + Corning Gorilla Glass II, coupled with 3 megapixel front facing camera and 13 megapixel rear facing camera, the official standard is powered by 2,000 mAh battery capacity, and the high version is powered by 3,000 mAh battery capacity.
    Although the Jiayu G5 is more comprehensive, this phone support for OTG / W + G dual sim dual standby / dual speaker Noise Reduction / gyro / electronic compass and joined the Yamaha sound chip upgrade.
    The phone has 130 x 63.5 x 7.9mm body dimension, inside the fuselage frames, borders, and the back cover are made of stainless steel, metal + slim appearance, which is the difference between Jiayu G5 significantly different from conventional products kae this phone is look elegant and valueable
