Today we 1949deal provides you with iOcean X8 ROM to update your smartphone to Android4.4 kitkat OS, and we also have good news that there is a great promotion that if you buy iOcean x8 right now, you can get a free leather case and a screen promotion, the price is very attractive at $269.99 now. What’s more, you can enjoy more promotion by this Summer Clearance sale,
http://www.1949deal.com/promotion.html
By the way, the clearance sale will be over on September 2. Don’t forget to have a look at it.
See the procedures about how to install ROM on your iocean x8.
Download iOcean X8 ROM here: http://pan.baidu.com/s/1bn1YvEn
Description
ROM Phone iOCEAN X8 – ROM Android 4.4.2
Official ROM iOCEAN X8 Version: X8 20140723-202036 – mt92_s5_os501_ousheng_kk_wcdma_ldata_tphone
Gapps include – No rooted
Language support: Multilang
ROM Install :
CWM
Step 1: Download the custom ROM copied to an external SD card root directory
Step 2: the shutdown state. While holding down:
– Power button + volume button up, to enter the recovery mode.
– Wipe Data / Factory Reset -> delete all user data
– Wipe Cache Partition -> Wipe cache
– Advanced -> Wipe Dalvik Cache
Step 3: Return to recovery main interface Install zip from sdcard -> choose zip from sdcard -> Select your ROM
Step 4: Brush complete, restart the phone Patience required – first boot takes a while
Here are the tips that help you how to update your iocean x8 to android4.4 kitkat, just have a try, if you have used how to flash firmwave about your smartphone. Please don’t forget the clearance sale about iOcean smartphones. Hurry up. You can shine!
