Hello guys, Android L is now becoming the most discussed topic all over the world. Today we bring you the best feature of Android L which is actually its boot animation that has awesome effects that really gives the feeling of Stock Android ROM working on your MTK Chipset!
[ATTACHMENT NOT FOUND]
Compatibility of Chipsets to proceed further with this tutorial:
Android L Boot Animation for MTK6589 smartphones
Android L Boot Animation for MTK6582 Smartphones
Android L Boot Animation for MTK65XX Smartphones
Things you must be equipped with to proceed to install Android L BootAnimation on mtk6589 OR mtk6582 chipsets is :
Your Device must be rooted.
You must have Root Explorer Installed with R/W access of the Root System.
Procedure To Install Android L Bootanimation on MTK smartphone
• Download the bootanimation.zip from the here and move it to your phone ( SD card or internal storage ).
• Now navigate to system/media through Root explorer. You can find an existing bootanimation.zip there. Copy it and keep somewhere in your sd card or internal memory. ( This is for restoring back to your stock bootanimation in case you don’t like this )
• Now replace the existing thing with the bootanimation.zip you downloaded.
• Now in root explorer select the file and click set permissions. Set the permission as rw-r–r–
• Exit root explorer and restart your phone.
• Enjoy ! Now you can see the latest Android L animation while your phone is booting.
