Increase UMi Super battery life up to 3 days
- This topic has 0 replies, 1 voice, and was last updated 10 years, 4 months ago by .
Battery life is a key feature for today’s smartphones and not too many devices manage to get the maximum out of their few mAh. UMi Super carries a 4,000mAh battery which should give the handset a good battery life but the company gives us some extra tips to increase it up to 3 days.
UMi Super runs on pure Android 6.0 debugging battery saver mode to stimulate 4000mAh potential. To help improve battery life, battery saver limits vibration, location services and unnecessary background data. It will also auto turn on when your UMi Super battery capacity falls down to 10%.
1. Long pressing home button to clean all running APP background.
2. From Settings > Apps, you’ll see a list of apps that are currently running,swipe to the left and you could force stop.
3. Find “Background task clear” and choose what apps you don’t need.
Set your various messaging apps to “white list” for the polling or refresh frequency, by using “Background task clear” in the settings of UMi Super. And you’ll instantly extend your device’s battery life by a significant amount.
It’s great that today’s phones have LTE, GPS, Wi-Fi and Bluetooth, but do you really need all four activated 24 hours per day? Swipe down Quick Settings from the top of the screen, and then turn off any of the above when you don’t need it.
Using Breathing light instead of unlocking the screen to check your notifications as the screen consumes far more energy.
Turn down the brightness and turn off Automatic Brightness You will be surprised by how much UMi Super improves its battery life.
The second UMi Super OTA update is already pushed this week. The biggest optimization is the enhanced battery life by 30%, much longer than before. So you should make sure your UMi Super is up to date.
You can still catch the 20 pieces giveaway here: http://umidigi.com/page-umi_super.html
