Hyundai Play X Release
- This topic has 4 replies, 5 voices, and was last updated 12 years, 3 months ago by .
Viewing 5 posts - 1 through 5 (of 5 total)
Hyundai Play X is a Retina display android tablet made and marketed by Hyundai Inc. The device has a 2048×1536 resolution IPS screen with 3.14 million total pixels, pixel density (definition) reaches 264 ppi. In addition, Hyundai Play X (X900) houses a dual core Rockchip RK3066 processor which is based on the 40 nm LP process of low-power and its frequency reaches 1.6 GHz. The quad-core graphics processor with 1GB of RAM with the help of POP special technology can drive the retina screen and make large-scale applications and games run smoothly. It runs Android 4.1 and has two built-in cameras: front camera is 2.0 MP, rear-facing one 5.0 MP. The 10-points Multi-touch make you easy play some video games, like Fruit Ninja. In addition, it’s equipped with a 10’000 mAh Li-ion battery which can support you 8 hours working time.
Looks Based on the original slim design style, Hyundai Play X (X900) brings a lot of stylish and innovative elements into the appearance, elegant black surface panel plus silver frame design is very eye-catching. The front part of the device is a 9.7-inch retina screen with a resolution of 2048×1536, 4:3 screen ratio. It looks simple but not cheap. The border and bottom of Hyundai Play X (X900) is done in accordance with integration silver magnesium alloy design and matt oxidation technology, stylish appearance, superior texture. From the side view, Hyundai Play X (X900) is thin, about 9.5 mm.
Hardware Performance The device is powered by Cortex A9 Dual Core RK3066 1.6 GHz CPU and GC-400 MP4 Quad Core GPU. It has 1 GB RAM and 16 GB ROM. Strong performance of the combination can be able to drive retina screen well and make large-scale applications and games run more smoothly.
Screen To display the delicate details, the device must have ideal contrast screen. The contrast ratio of Hyundai Play X (X900) 9.7-inch retina screen is up to 800:1 and brightness of 440 cd/m², make the whole picture is close to the nature. In a dim hue picture, if you want to move up local static picture through dynamic effects, the contrast and brightness of the screen is the key. High contrast and high brightness make dim spatter broken foam showing blasting light and shadow, the entire static screen is immediately alive.
Fantistic RGB display is one of the prominent features in Hyundai Play X (X900), the screen comes with 8bit 1670 million color display, RGB display quality is more accurate and natural and special.
i want the buy this tablet. is it a real 10000 mAh battery?
i have got one,it’s awesome
Thanks for the valuable informations shared. Before buying this phone definitely read your review carefully.
Hyundai is trustworthy, you can have my honest word on this. They have good cars, but their phones are even better!
