Today, some smartphone manufacturer is turn their product with larger screen, staring 5 inch to 6 inch is more popular now. After samsung is launch the Samsung mega with 6.3 inch screen size, Sony XL39H with 6,44 inch screen and Huawei Ascend Mate with 6.1 inch screen size, there is another manufaturer that offers the same aspect, the Hyundai MultiCAV Q6.
Hyudai MultiCAV Q6 is the one of Chinese smartphone that’s packs with 6 inchs screen size, but the interesting point is those screen is capable to read user handwriting through thestylush pen.
The design is par with Samsung Galaxy lineup, even the user interface is almost similar, so some people maybe guess this device as Samsung Galaxy Note but this is Hyundai MultiCAP Q6 Android smartphone.
Hyundai Multi CAV Q6 is a modern digital’s first 6-inch mobile phones, today is the first time this phone has been exposed in public. The handset comes with 6-inch HD resolution LCD screen, its has 1280×720 resolution for 244 PPI, is still very high degree of detail.
A special feature is that in the bottom of the back of the phone is a stylus pen, stylus looks like a plastic material, it is not equipped with buttons and battery port, while the phone’s screen is a capacitive screen, this plastic pen can be use as a precise operation.
Hyundai Multi CAV Q6 is a modern digital’s first 6-inch mobile phones, today is the first time this phone has been exposed in public. The handset comes with 6-inch HD resolution LCD screen, its 1280×720 resolution is 244 PPI, is still very high degree of detail. A special feature is that in the bottom of the back of the phone found a stylus, stylus looks like a plastic material, it is not equipped with buttons and battery port, while the phone’s screen is a capacitive screen OK, this plastic pen can In the capacitive screen on precise operation, of which some confusing technology.
Modern Q6 has slim design with 9.25 mm body thickness, body edges are rounded, the border is relatively narrow, even if the screen has six inches screen size, the whole grip is still very good.
We see this model, front and back are white, which is surrounded by a circle surrounded by shiny silver metal front of the phone has a home button, the other two Android commonly used menu and return keys are located on both sides of the Home key, touch button will light up when using.
There is also 13 megapixel main camera on the rear ith flash light. This phone is powered by quad-core chipset, supports for WCDMA 3G network, as well as more of a GSM card slot supports, Wi-Fi, Bluetooth, GPS and packs with 2050mAh battery capacity, the whole weight of 180 grams.
