The Honor 6 uses Smart Control 2.0 technology which can be used to control electrical appliances.
Everyone in the audience got a free Honor 6. Its motherboard is 38% the size of the Samsung S5.
It benefits from an adjustable antenna and powerful and a battery with a high energy density which explains the Honor 6’s small size.
The Honor 6 is 12.5% the size of the Samsung S5.
2.86mm frame and 75.7% screen ratio.
Sports a 5-inch 1080p display screen, is JDI supported, and uses Corning Gorilla Glass 3.
The Honor 6 has a very good radian measure and can fit in the palm of one’s hand.
The Honor 6 has a very metallic structure.
3D light streaks, formed in 6-levels
The look of the Honor 6 was inspired by a peacock’s feathers
The Honor 6 has two TCGS-S chips.
Can lower the phone’s temperature by 4-6 degrees.
The Honor 6 is made of aluminum alloy which gives the phone higher thermal conductivity.
With mild use, it can last for over two days, but with heavy use, it could only last for a day.
A highly dense battery can decrease chance of overheating.
The Honor 6 uses a 3100mah battery which is pretty good.
Honor 6 phone cases
Here is the Honor TalkBand.
Huawei’s commentator showed the honor cube 。
