Huami Launches GPS Equipped Amazfit Sports Smartwatch for 799 Yuan ($120)
  • #11734
    True to their words, Huami officially launched their Amazfit smartwatch today. The watch which has a built-in GPS, a pedometer, a real time heart rate monitor, also displays weather information and is priced at 799 Yuan ($120).
    005HYW27jw1f7auvz32mbj31kw1ll13z
    The Amazfit watch has a 1.34” diameter, a 22 mm quick-release replaceable sweat-proof strap, a scratch-resistant ceramic bezel, IP67 certification, 1.2GHz dual-core processor, 512MB RAM, 4GB RAM, Bluetooth 4.0 Low Energy, and WiFi. The display which has a 320 x 300 resolution uses a reflective screen to increase legibility outdoors. There is also an app where users can monitor the readings of the watch.
    005HYW27jw1f7bs6jslxuj30k00fy0tv
    Huami has designed the watch to be able to store up to 500 songs which you can listen to via a pair of Bluetooth earphones, so you don’t have to take your phone along for a run. They also have a partnership with Watercress FM to provide music streaming.
    The watch will also be able to carry out basic smartwatch functions such as call and SMS notifications and have support for Alipay.
    Huami says the 280mAh battery will last for 11.6 days if you use it just as a plain watch but normal usage (30 minutes run + 200 push messages) will get you 5 days of life. However turning GPS and heart rate monitoring on will get you 35 hours of battery life.
    Full Specifications of Huami Amazfit Sports Smartwatch
    • 1.34” 320 x 300 reflective screen
    • 22mm replaceable straps
    • 4GB ROM
    • 512MB RAM
    • 1.2GHz dual-core processor
    • BLE 4.0 + WiFi
    • GPS + GLONASS
    • PPG heart rate monitor
    • IP67
    • 53.7 grams
    • 280mAh battery
    005HYW27jw1f7av6jncsij31kw3gz189
    Availability
    There is no news on the watch having other colours but users can change the watch face to suit their preference. The Huami Smartwatch will officially go on sale tomorrow.
