How to recover Lost Data from Android smartphone using Coolmuster Lab.Fone for Androi
- This topic has 8 replies, 8 voices, and was last updated 10 years ago by
Haofpo.
March 11, 2015 at 11:10 AM #7973
MemberThere have been plenty of instances where data on an Android phone is lost. Most of the times, it is just accidental deletion, and a few other times formatting. Whatever the reason may be, there will be times when you have realized that an important file or folder on your device is now gone. While its natural to panic in such a situation, you have to realize that just because the data is not available on your smartphone doesn’t mean its lost for ever.
When you accidentally delete a file, the file is not really erased from your device. Most of the time, you can recover lost data without much hassle. This is where the Coolmuster Lab.Fone for Android comes to your rescue. This particular desktop application scans your Android smartphone for any recoverable files and then gives you the option to recover each file, one by one. This desktop application is ideal for someone who has lost an important message, contact, or even file on the device and they need it urgently.
Since recovering lost data is not an easy task, its always better to root your device before using Lab.Fone. Root access grants the app extra permissions to make sure that everything that’s recoverable can be found on your phone.
Interestingly, the company has given a guide to root your device before you use their app and hence, you can check out their guide if you have not already rooted your device.
Anyways, here’s how you recover your deleted files on your smartphone / tablet.
1. Connect your phone / tablet to the computer.
2. Install and launch the Android Data Recovery Software.
3. Select USB Debugging mode on your device.
4. Now you’ll see a pop up window where you should click on Allow. This will give the app necessary permissions to scan your phone for any recoverable files.
5. Once the scan is completed, you will see a number of files available for recovery in different categories like contacts, text messages, videos etc. You can go to each category and select a file to recover.
6. Once you have found the files that needs to be recovered, just click on the RECOVER button on top. This will undelete the file and transfer it to your computer.
See, its as easy as it sounds. You can check out more details on how to recover data from Android via the given link. And if you are just want to recover messages from Android phone, they have a separate guide for that too.
This is one of the easiest ways to recover lost data. So, now you don’t have to worry if you accidentally delete a file as this software will help you find it back.
June 18, 2015 at 3:32 AM #18491qiaolus
MemberCool article. Alternative to Coolmuster Lab.Fone for Android–Vibosoft DR. Mobile for Android, MobiKin Doctor for Android and more.
How to recover Lost Data from AndroidAugust 24, 2015 at 2:55 AM #18509chanleen
ParticipantWhether you can recover texts from a broken Android phone or not,you can recover lost data on Android phone. However, it depends on the phone itself. You’d better not created new data on your phone after the message loss. Now, let’s be optimistic.
To recover lost data from Android, I’d like to recommend using Tenorshare Android Data Recovery, it can help you.
March 21, 2016 at 2:32 AM #18580augustk
ParticipantThe user interface is ugly, lol. Androidphonesoft has a better program for retrieving deleted files form Android phone. It supports a lot of Android smartphones and tablets. Android version 6.0 is also well supported.
May 10, 2016 at 6:39 AM #18588Hileman
Participantchanleen wrote:Whether you can recover texts from a broken Android phone or not,you can recover lost data on Android phone. However, it depends on the phone itself. You’d better not created new data on your phone after the message loss. Now, let’s be optimistic.To recover lost data from Android, I’d like to recommend using Mobiledic Android Data Recovery, it can help you.
I downloaded it and found it asks me to root my phone, but I don’t want to root my device, any other way that could recover my deleted messages from Android phone?
May 11, 2016 at 1:34 AM #18592Hileman
May 30, 2016 at 9:37 AM #18600Xkoiul
MemberThanks for sharing.
May 31, 2016 at 7:52 AM #18606Colleen11
ParticipantI don’t wanna root my phone, any other way to recover photos from galaxy s6?
October 9, 2016 at 3:48 AM #18646Haofpo
ParticipantThis is not a difficult,i found on Google a very easily way to recover lost data ,like Android Rescuer tool, and i succeeded recover lost data from android ,don’t damage to original phone data or device,
