How to fix GPS problems on MTK6577 & MTK6589 phones
- This topic has 10 replies, 6 voices, and was last updated 12 years, 6 months ago by
October 10, 2013 at 9:51 AM #4669
MemberCheck the newest guide here:
https://droidchina.com/guides/improve-gps-performance-for-mtk-chipset-phones-tablets[video=youtube]http://www.youtube.com/watch?v=ZnY_425NgB0[/video]
Jiayu G3 G4 GPS fix:
[video=youtube]http://www.youtube.com/watch?v=NsUSvd-SlVo[/video]iOcean x7 GPS fix (DIY antenna – great result):
[video=youtube]http://www.youtube.com/watch?v=2q_AmYlrwNc[/video]Solve MTK GPS fix problem:
[video=youtube]http://www.youtube.com/watch?v=2EhPUvviXoQ[/video]How to get faster FIX position on GPS (EPO) | MTK | ZOPO | ZP980, ZP990 …
[video=youtube]http://www.youtube.com/watch?v=efShzudFWQk[/video]November 23, 2013 at 4:46 PM #15080ctscts
ParticipantIn my rooted Morotola Razr D3 (XT920) firmware 2_32D_2009 (Brasil) it´s not possible to enter MTK Engineering mode (Mobileuncle MTK Tools in play store), even it is a MediaTek MT6577 based phone. When I touch this option, the screen blinks and nothing happens.
What I did in my case, was change this two files below (root needed, folder /system/etc – you can use root explorer/built in text editor to change this config files)
file “conf.gps” , delete everything and put this:
NTP_SERVER=0.south-america.pool.ntp.org
NTP_SERVER=1.south-america.pool.ntp.org
NTP_SERVER=2.south-america.pool.ntp.org
NTP_SERVER=3.south-america.pool.ntp.org
NTP_SERVER=0.br.pool.ntp.org
NTP_SERVER=1.br.pool.ntp.org
NTP_SERVER=2.br.pool.ntp.org
NTP_SERVER=3.br.pool.ntp.org
XTRA_SERVER_1=AQUIxtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_2=AQUIxtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=AQUIxtra3.gpsonextra.net/xtra.bin
SUPL_HOST=supl.google.com
SUPL_PORT=7276
SUPL_TLS_HOST=lbs.geo.t-mobile.com
SUPL_TLS_CERT=/etc/SuplRootCert
INTERMEDIATE_POS=1
ACCURACY_THRES=2500
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_USER_PLANE=FALSEChange where its says AQUI for h t t t p : / / (all together)
You can change the NTP servers to your country settings (go to pool.ntp.org and find it.file “epo_conf.xml” – at the end of file, change to “yes”:
epo_enable=”yes”
auto_enable=”yes”
update_period=”4320″
/>Make sure the permissions for the two files (gps.conf and epo_conf.xml) is RW-R–R–, if it is not, change it.
Go to play store and install app “GPS Status & Toolbox”, test the GPS outdoors. I hope it works to you, in my Razr D3, now, it takes less than 60 seconds to synchronize to satellites, before, could take more than 10 minutes.
[hr]
Forgot to say, after edit the files, reboot the phone.January 21, 2014 at 5:56 PM #15744skan
MemberHi.
I’m considering getting a cheap Chinesse phone but the GPS problem keeps me from buying it.
What cheap brand doesn’t suffer the problem (Meizu, Jiayu, THL, UMI, Zopo, Inew, Huawei…).I don’t mind if there is just a “software” option but I don’t want to buy a mobile with a bad GPS chipset or even without antenna.
Regards.
January 22, 2014 at 6:34 PM #15752imported_umit
MemberI have Jiayu G2 and it gets a fix in 2-3 minutes without any special software or setting. My Samsung Galaxy Tab 2 gets much faster fix. I think all MTK chipset phones have slow fix problem. Some of them even does not get a fix for long time.
January 23, 2014 at 1:37 PM #15757skan
MemberHi man,
And do you know if the brand ZTE also uses mediatek and have the same problem?
For example the model ZTE Z5s.
In some places the specs say it can also use Glonass, in other it say not.
Anyway this brand is much more expensive.What I don’t like is that it seems you can’t replace the battery and it’s only 2000mAh. I don’t know if it could be possible to replace it even if it’s not supposed to.
regards
January 23, 2014 at 3:47 PM #15759imported_umit
MemberI don’t have that information. Sorry.
January 23, 2014 at 9:06 PM #15761skan
MemberThank you anyway
February 6, 2014 at 8:25 AM #15868Iftikhar Hussain
ParticipantI try to open my weather App but its not showing weather result and even not get my location my wifi and 3G is working
February 15, 2014 at 3:08 PM #15930shabberkazmi
Memberthanks
March 17, 2014 at 9:32 PM #16235s7yler
Memberthanks, but none of these tricks worked for me
April 24, 2014 at 2:03 PM #16674imported_umit
MemberI put a link for new “MTK chipset telephone GPS performance improvement guide” in the first post.
https://droidchina.com/guides/improve-gps-performance-for-mtk-chipset-phones-tabletsPlease discuss the new guide in this thread:
https://droidchina.com/forum/Thread-Howto-Improve-GPS-Performance-for-MTK-Chipset-Phones-Tablets -
