Last year, Doogee unveiled a new brand of smartphones called as the HOMTOM which focused on large batteries. Given that phones which can last for a couple of days on a single charge are popular among customers, the HOMTOM smartphone lineup seems like a practical brand at the moment.
The latest smartphone model in the lineup is the new HOMTOM HT7 Pro which brings pretty good specs and value for its super cheap $89.99. Even the overall design is pretty good for a budget phone, featuring a classic brushed metal back cover. The phone’s also thin, measuring just 7.9mm in thickness.
As for the specs, the HOMTOM HT7 Pro comes with the decent MT6735 64-bit quad-core processor under the hood with 2GB of RAM and 16GB of expandable internal storage. These are good specs for a sub $100 device. As for the display, you have a large 5.5-inch IPS screen with 1280 x 720 pixel HD resolution.
Cameras are also standard, featuring a 13MP sensor at the back and a 5MP sensor up front. Connectivity features include 4G LTE support, Wi-Fi, Bluetooth, and GPS. Also, you get Android 5.1 Lollipop OS out of the box.
Finally, for battery, which is the highlight of the device, you get a large 3000mAh capacity battery pack on board, which should power the device for a couple of days easily. As you can see, the specs are pretty good and the overall design is also attractive. Looks like you have got yet another good looking budget smartphone to consider.
Check out more details like supported bands and shipping from the link given below. The phone is currently up for pre-order at lightinthebox for $89.99 in black and silver color options.
