Here’s ZOPO ZP530 full specifications and beautiful images
- This topic has 0 replies, 1 voice, and was last updated 11 years, 9 months ago by
February 12, 2015 at 11:10 AM #7880
MemberJust two days back, we reported that ZOPO is all set to release a new device in the market. Now, we have received a lot of new photos that show off this upcoming device. We also have the ZOPO ZP530 full specifications, so all those readers who were asking for more information can finally relax and take a look at the specs given below.
First of all, lets take a look at ZOPO ZP530’s design. There is no doubt that the phone takes its design inspiration from last year’s iPhone 6 model. And this is exactly why the device looks so good.
On the front, the ZOPO ZP530 sports a 5-inch 720p IPS ONCELL Full Lamination display. Above the display, on the left lies the 5MP camera, while on the right of the ear piece are the sensors. Below the display there’s a round home button similar to iPhone. The front features 2.5D arc glass, which makes it look even more premium.
Coming to the back, the phone has an IML Fashion Vein cover, which further enhances its looks. There’s an 8MP camera on the top with f/2.0 aperture and LED flash. Below, you’ll see the ZOPO logo along with the speaker grill.
The buttons are made of metal and so is the frame that runs around the device. On the right side, you have the volume rockers, while on the left, you get the power button.
Coming to the ZOPO ZP530 full specifications, the phone features the MT6732 quad-core 64-bit processor based on Cortex A53 architecture and clocked at 1.5GHz. For GPU, the phone has ARM’s Mali 760 MP2. The 8MP camera is capable of recording 1080p FULL HD resolution videos. Inside, there is 1GB of RAM along with 16GB internal storage further expandable up to 64GB via MicroSD.
Connectivity features include Wi-Fi, Bluetooth, GLONASS / GPS / A-GPS, and GSM+WCDMA+FDD-LTE support. The compatible frequencies are given below. As for battery, you get a decent 2100 Li-Polymer battery inside, which should last for a day with moderate usage.
ZOPO ZP530 full specifications are as given below:
Main Features Transmission Function Appearance PDA GPS model (hardware) Yes 3G video call Yes A-GPS Yes OS android 4.4 Wi-Fi Yes(802.11a/b/g/n) Smart phone Yes WIFI hot Yes CPU model MT6732 (28nm HPM) Bluetooth Yes(4.0) CPU Quad-core PC DS
( Data Synchronism )Yes CPU frequency 1.5Ghz Wifidisplay Yes GPU ARM Mali760 MP2 500MHz Personal Assistant Keyboard virtual keyboard Email Yes Network Caculator Yes Network GSM+WCDMA+FDD-LTE Alarm Yes Dual-card Yes Calendar Yes Network frequency GSM:850/900/1800/1900MHz Recorder Yes WCDMA: 900/1900/2100MHz Call recorder Yes FDD-LTE: 800/1800/2600MHz More Broswer Yes Gravity sensor Yes Memory Accelerometer Yes (3 axis) ROM 8GB ROM Range sensor Yes RAM 1GB RAM L-sensor Yes Micro-SD MicroSD(TF) Geomagnetic sensor Yes Extended Memory 64GB Hall sensor NO Display OTG Yes Size 5.0″ IPS ON CELL, Full Lamination Technical NFC NO Color 1600 SIM size SIM1(Micro)+SIM2(Nor) Resolution 1280*720 Bluetooth mouse Yes Touch screen Capacitive screen Bluetooth keyboard Yes Touch screen specification Five Breathing Lamp Home Key Gravity sensor Yes Battery Li-polymer L-sensor Yes Battery capacity 2100mAh Range sensor Yes Battery change Yes Camera Holding time > 10 hours Back camera 8.0MP Standing-by time >120 hours front camera 5.0MP Side key volume+/volume-,power Sensor type CMOS Cable Micro USB Flash Yes USB 5pin micro USB Video Yes Earphone standard 3.5mm Phone Size 145mmX71.2mmX8.8mm Weight 145g(including battery) Entertainment Functions Music Yes Recorder Yes Video Yes(1080P vdieo, 1080P video record) Bell Mp3/aac/asf E-book Yes Flash Yes -
