HELP PLZZZZZ
Viewing 5 posts - 1 through 5 (of 5 total)
  • #4379
    Raechel Hart
    i bought a HDC Galaxy S4 U9500- MTK6589 and inserted my vodafone sim , i can make calls etc but it wont connect to the internet without the wifi , its running android 4.2.2 will rooting it solve this problem?
    also under mobile network state its says disconnected.
    #14137
    Rooting will not help. Have you checked APN settings?
    #14138
    susegebr
    in order to acces internet through your vodafone sim card you have to have a APN for vodafone
    search for apn vodafone android and you will find a howto to edit the APN
    succes
    #14610
    newbilou
    I Have the same Phone, but i need the rom.
    Can you make the backup and stock this on MEGA (for example)
    Plzz:-/
    [hr]
    #14614
    ChiChai
    You can also call Vodafone to have a customer service agent walk you through editing the APN so you can make use of your sim for the internet.
