Help me Please !!!
- This topic has 6 replies, 5 voices, and was last updated 12 years, 8 months ago by .
Viewing 7 posts - 1 through 7 (of 7 total)
my Gionee Pioneer P2 after I install Chainfire3D it reboot and get stuck at the logo Gionee , I rooted my phone but I did’nt install CWM or any custom fastboot I just have the standard boot , I can boot into the standard fastboot with the menu :
– reboot system now
-apply update from ADB
-apply update from sdcard
-apply update from sdcard2
-wipe data/factory reset
-wipe user cache
-backup user data
-restore user data
– I tried to wipe data/factory reset but it still got stuck at the logo
– I used apply update from sdcard with other rom but I got
“Installation aborted”
-someone plese help me !:exclamation:
-sorry for my bad english.
Sorry to hear that your phone is unusable.
Can you try to flash ROM using PC?
Can you try to flash another ROM using sdcard and recovery?
The system recovery standard doesn’t allow to flash other rom or even the current rom it’s using ,
you can only update to a higher version, i think so
so i need a custom recovery like ClockWorkMod Recovery but I tried to install it in The system recovery standard and i just got “Installation aborted”
, is there any ways to install CWM in my case ?
Help me !!!!!
all the forums i ‘ve found they just show how to install ClockWordMod when your divice can start normally and then connect to the Pc but i can’t start the system successfully, so i can’t connect my divice to the pc.
Can I install the CWM in The system recovery standard ? please help !!
dude try to re-flash and re install rom if it giver error again i am afraid it is bricked and useless. sorry to inform you this
Do a nandroid Restore via custom recovery(CWM) and u’ll hav ur phone back.
Hi friends,
I have gionee p2. I have rooted framaroot. I have very small knowledge about android. But I am interested to learn things. In this process, after rooting phone, gionee p2, I have installed chainfire 3d. After reboot, my phone stocked at logo. I have no idea what to do next. Please anybody help me.
Thank you.
Hello,
I hope this thread can help u.
Shit i cant post link.
go to forum.xda-developer
with number thread 2485942
