Get the UMI Iron Pro for $20 Off at Banggood.com
  • #9639
    UMI and Banggood.com are holding another promotion for UMI’s latest flagship the Iron Pro which brings the price of the smartphone down by $20 using a coupon code – 20ironpbg. The promotion is limited though as only 100 pieces will be put up for grabs and the promotion runs from November 16 to 22. The UMI Iron Pro is normally priced at $179.99 so with the coupon code you’ll be able to grab it for only $159.99.
    banggood-umi-iron-pro-sale-01The UMI Iron Pro is the company’s latest flagship smartphone that features a 5.5-inch full HD 1080p display and a metal unibody that measures only 7.9mm thin, weighs 148 grams, and comes in either silver or black. It features a MediaTek MT6753 1.3GHz octa-core processoer, an ARM Mali-T720 graphics chip, 3GB of RAM, and 16GB of internal storage.
    It’s also equipped with a rear mounted fingerprint sensor, a 13-megapixel rear camera with a f2.0 aperture lens and a Sony IMX214 sensor coupled with a dual LED flash, an 8-megapixel OV8858 front-facing camera, a 3300mAh battery, a hybrid SIM card slot that supports either two Nano SIM cards or one Nano SIM Card and one MicroSD card up to 64GB in capacity, and a USB Type-C connector.
    As previously mentioned, the UMI Iron Pro can be purchased for only $159.99 using the coupon code – 20ironpbg – and is scheduled to ship starting November 30, 2015. Don’t miss the chance, just check this Banggood promotion active.
