Get the Oukitel U8 for As Low as $129.99 from AliExpress
  • #8665
    For a limited time, you can purchase the Oukitel U8 for as low as $129.99 from AliExpress which has featured the U8 (which is also known as the Universe Tap) in the store’s Tech Discovery section as one of its key recommendations.
    oukitel-u8-aliexpress-sale-01The Oukitel U8 is a mid-range smartphone that comes equipped with a few high-end features including a rear-mounted fingerprint sensor similar to the one found on the Huawei Mate 7 as well as bezel-less design and 2.5D arc glass. It also runs Android’s latest 5.1 Lollipop operating system.
    The U8 also features a 5.5-inch HD IPS display with a screen resolution of 1280 x 720 pixels, a MediaTek MT6735 1.0GHz quad-core processor, 2GB of RAM, 16GB of internal storage with support for expandable storage via a microSD up to 64GB, and a 2850mAh battery.
    It’s also equipped with a 13-megapixel rear camera coupled with a dual-LED flash as well as a 5-megapixel front-facing camera. Lastly, it supports dual SIM dual standby, 4G/LTE FDD connectivity, WiFi, Band luetooth 4.0.
    The Oukitel U8 (Universe Tap) will be available in either black or white for as low as $129.99 from AliExpress starting today until July 7, 2015, so gets yours now.
    Buy Now[source]
