Get $10 Coupon for Blackview BV5000 and promotion of Letv ONE/S1
- This topic has 0 replies, 1 voice, and was last updated 11 years ago by
smartphone mania.
October 20, 2015 at 3:50 AM #9425
smartphone mania
Participant[size=medium]
[size=large]Get $10 for Blackview BV5000[/size]
Often we want a robust and waterproof smart phone at an affordable price. And today i will recommend you the Blackview BV5000, a very robust 4G LTE and Dual SIM smart phone with camouflage body, waterproof and very powerful battery of 5000 mAh. Why I recommend this device not only because its good specifications but also it has $10 coupon code for you now until the end of Oct. Here the coupon code: bv5000coral
[ATTACHMENT NOT FOUND]
Blackview is Chinese company that dared to be different and braver than others. They made Blackview BV5000 smartphone a water-resistant (IP67 certification), resistant to dust, drops, shocks and vibrations, they dressed him in camouflage casing that comes in several colors and embed it a strong battery.
One of the strongest feature is the battery of 5000 mAh and supports Reverse Charging technology, which means that this smartphone can charge other smartphones (as shown). Otherwise, the daily use of the battery should hold two to three days of work.
The screen is a 5-inch IPS HD resolution of 1280 x 720 pixels, and it is interesting how the screen work if you tapped on it with wet hands. The device runs on 64-bit MT6735M 4-core processor clocked at 1.0 GHz and Mali-T720 graphics MP2 at 500 MHz. The device is built in 2 GB of RAM and 16 GB of internal memory, 2MP front camera and 8MP rear camera(with interpolation up to 16 MP), with LED flash and auto focus. The smart phone runs on Android 5.1 Lollipop operating system, supporting dual SIM, and 2G / 3G / 4G network (2G: GSM850 / 900/1800/1900 MHz 3G: WCDMA 900/1900/2100 MHz 4G: LTE FDD: B1 2100 / B3-1800 / B7-2600 / B20-800). It also supports Wi-Fi, Bluetooth 4.0 and GPS. Otherwise the dimension is 150.7 x 78.1 x 11.99 mm, weighs just 145 grams and comes in three attractive colors – black, camouflage green and sunny orange.
This robust and waterproof Blackview BV5000 smart phone can be found at 1949deal webshop at a great price of $ 159.99(get the coupon code for $149.99). All additional details, see and make purchases on this link.
Blackview BV5000 test of waterproof、freeze-proofing and dustproof
[video=youtube]https://www.youtube.com/watch?v=vvJpcoVpN-U[/video][size=large]Letv one/s1/x600 promotion[/size]
1949deal store makes a promotion about Letv one/s1/x600, which includes 3GB RAM and 16/32GB ROM.
[ATTACHMENT NOT FOUND][ATTACHMENT NOT FOUND][ATTACHMENT NOT FOUND][ATTACHMENT NOT FOUND]
It’s a device running on a 64Bit MediaTek Helio X10 Octa Core processor clocked at 2.2GHz. The device also uses the EUI for its user interface, which is designed by Letv rather than android. The screen is 5.5 Inch 1920 * 1080 Pixel FHD Sharp IPS Screen and 9.5mm Ultra Slim. It has two versions, 3GB RAM and 16GB ROM, and 3GB RAM 32GB ROM, and they sell $179.79 and $206.99 respectively at 1949deal store. The camera is 13.0MP of Back Camera and 5.0MP of Front Camera. 2G, 3G, 4G(2G: GSM 850/900/1900/2100MHz; 3G: WCDMA 850/900/1900/2100MHz; 4G: FDD LTE: 1800/2100/2600MHz; TD LTE: 38/39/40/41) are supported, as well as OTG, WIFI, GPS, Bluetooth, Multilanguage, Play Store, etc. The battery is 3000mAh, which is large enough for you to run a smart phone smoothly.LeTV One/X600 s1 Hands on, Antutu, Camera, game, GPS, Battery review[/size]
[video=youtube]https://www.youtube.com/watch?v=O02KbKq85TI [/video]:heart: -
