[FREE] Signal Booster
- This topic has 1 reply, 2 voices, and was last updated 12 years, 4 months ago by
Rohan99.
July 4, 2014 at 6:46 PM #6423
killu
Member[IMG]https://lh5.ggpht.com/zkmizt93QoeVVhoT5tpU3YfcZ1il3KeI-rNV5cMtI2AmLsb0t-A3LJNt6BabQXp_Txz6=w300[/IMG]
Hello,
We have introduced a new app Signal Booster
[IMG]https://lh4.ggpht.com/qLUBpIqugwRs6w3fO6ackfCzDoFkeaBhkxle_5fsq-Yg1BADJAOH3pE4oOPPsTZiG6w=h900[/IMG] [IMG]https://lh4.ggpht.com/r__b48Cpu8mVG8I2Ble3DW8xeSpUKi8csgQC7L1o2fz6nEUlgGaTYyp-mbVqPxbLPsI=h900[/IMG]
Description:
Signal Booster
The first working #1 Signal Booster for Android.Are you tired of having weak signals and low internet speed in your area?Don’t worry you have come to the right app.Signal Booster use’s its proprietary technology for boosting your signals and give you better connectivity.From now on you would never loose a call due to network connectivity issues.Signal Booster is a two in one app.It acts as Internet Speed Booster too[3g Speed Booster and 4g Speed Booster].Signal Booster is very simple app and is less than 1MB in size.
Signal Booster supports almost all android devices available in market.Just in case your phone is not supported just drop us a mail and you will have your phone supported in the next update.
Features Of Signal Booster
Improves Signal Strength
Acts As a 3g Speed Booster
Acts As a 4g Speed Booster
Very Small In Size
No battery drainage
Supports Many International Languages
When You Exit The App,Your Will Shown An App Of The Day Which Will Be Selected By Our Team.These are apps which we think would be useful for you.
How To Use Signal Booster
The usage of signal booster android is very simple.You just need to open the app from you menu or from the shortcut created on your home screen when the app was installed.App will automatically begin to boost your signal.Please note that you should wait at least 10 seconds after running the app to see the boost in your signal strength.
How Signal Booster Works
Your Android phone does not search for signal’s always.It does not care even if you are not connected to a weak tower.There may be high strength towers available in your area.But you Android phone does not connect to that tower unless all the signals from that weak tower is gone.Android does this to save your battery.But it does not understand that saving battery in this way is not useful.Signal Booster helps you connect to the tower with the highest strength.Signal Booster makes sure that you are connected to a quality network.Most of the signal booster’s in market use similar methods to boost signals,but they cause drainage of your battery too.But Signal Booster from Kallada Solutions is different.Using our proprietary technology we make sure that you are connected to the tower with the highest signal strength and also making sure that there is no waste of battery.
There are some cases where you would be having enough range but your internet would just not connect or your internet would only connect it 2g network and won’t connect to 3g network even if 3g is available.In all these case’s you just need to run your Signal Booster app once and all your problems would be solved.
If you face any problems running signal booster just drop us a mail or add us on skype.We have a dedicated team to help people in getting signal booster to work.
If you like Signal Booster do support us by dropping a good review.This will help us to create more apps like this in future.Link to google play store: https://play.google.com/store/apps/details?id=com.kallada.supersignalbooster
Requirements: Android 2.2 and Up.
Available for Android.
I recommend you to download this new and awesome app.
Enjoy!!July 5, 2014 at 2:34 PM #17560Rohan99
MemberI don’t know how these apps work or if they do at all. The matter of the signal strength of your phone is mostly hardware and I don’t think that a software can boost your signal strength much. I will test this app and find out for myself if it really works.
