Hi guys i just recently purchased an android Chinese phone.
the phone is made by hi-sky and its the hi-sky 2G9000-PANEL 3.
The phone worked perfectly on first use,, It was unlocked with no issues.
while playing with the phone i somehow managed to put a password lock on it
and i do not know how to remove it.
I have factory restored/wiped the phone countless times and what happens is when it reboots after the wipe i have access to use the phone with no issues but when the phone goes into stand by mode or the power button is pressed to put it into standby when you try to use the phone again it ask for a password,, one that i have no idea is..
so in order to access ANYTHING on the phone i have to do a volume down and power button press, wipe the phone and then reboot to get past the password screen,,
its really frustrating
so the Phone is a Hi-Sky 2G9000- Panel 3
dual sim smart phone with android 4.2.2
MT6572
MTK12345678910
with custom rom: M3N_TM_NOTE3_HISKY_V03_M140226_ML_FWGVA_GG
I am very new at flashing roms etc so if i do need to flash a rom to it may i get a FULL detailed description please..
i have searched for this phone model online and haven’t been able to find anything relating to it.
