First 8 Core Tablet, and it’s China-made!
- This topic has 8 replies, 6 voices, and was last updated 12 years, 3 months ago by
Rohan99.
October 15, 2013 at 1:45 PM #4699
ChiChai
ParticipantI was thinking about possibly getting a tablet that’s several levels better than my trusty Ainol Novo7 Venus and I saw TeamGee TG-8001 Exynos 5410 1.6GHz 8 inch Tablet PC Android 4.2 Eight Core IPS Touch Screen 1280*800 2GB/16GB while browsing the interwebs. Isn’t it crazy? Eight core?!
Anyways, here’s how it performs:
[video=youtube]http://youtu.be/UkPq9xqtOoE[/video]
And here are the highlights on its specs:
Android 4.2 OS
8 inch 1280*800 IPS capacitive touch screen
Samsung Exynos 5410 Eight Core 1.6GHz
2GB DDR3 RAM and 16GB NAND FLASH ROM
Support Bluetooth/GPS/3G/HDMI function
2G: GSM 850/900/1800/1900, 3G: WCDMA 850/900/1900/2100
Front 2.0MP + Rear 5.0MP camera with flash
Built-in Micro USB 3.0 interfaceThe specs do sound amazing and the best part is, I can afford it. If there’s anyone though who has experience with this type of tablet, can you share it? I would really like to be sure that this would be the tablet I will use for several years. Heh.
October 18, 2013 at 6:51 AM #14684Summer
MemberSamsung Exynos 5410 Eight Core 1.6GHz is amazing, but don’t know how it works. Just wait
October 18, 2013 at 3:42 PM #14689ChiChai
ParticipantHeh, I bet it works mostly like the usual Android phones. The performance might be better though. This isn’t top of the line type of phone but it’s good for the price, I think.
October 19, 2013 at 8:23 PM #14705imported_umit
MemberI am interested in this tablet too. But I couldn’t find it cheap. Close to Samsung galaxy tab 3 8 inch version. At Pandawill it is 310 usd. At tinydeal:
(TEAMGEE) Super 8 8″ Android 4.2 8-core 3G Tablet Phone $320.99 [video=youtube]http://www.youtube.com/watch?v=Nu1RtfJXMKM[/video]
November 19, 2013 at 6:43 PM #15007Christopher Chang Peng Yen
ParticipantHi.
I am currently using it.
I am having some problem with it.
So far the problems I have encountered, some are solved, and some are not.
1. Battery charge full very fast, but drain also fast.
2. Memory card, now keep jumping out.
3. Screen with a spot. That one solved as it had 2 layer of plastic screen cover.
4. It save copy of SMS into SIM card, and then indicate SIM full.
5. I encounter blank screen, often. It may be due to the Android programs that I install, as originally it did not have this problem. My other handset which is not Super 8 E1 also encounter this problem.I do admit the screen is good, and also play very good video.
The size is same as note 8. But buttons and connection points are not the same, and it is thicker. Which means it will not be able to fit in note cover cases. However, I bought the note 8 rubber case without any covering, and then cut away certain areas to uncover the speakers, buttons, mic, and connection points. That works well.
It uses the newer Note 3 USB 3.0 cable.
The power adaptor connector is not standard phone connector.
It is round.I will try to replace the firmware next month, when I have time.
November 19, 2013 at 7:40 PM #15008imported_umit
MemberThanks for sharing your experience with your tablet. I’ve posted a link where you can find roms for it and also a link to a rom with google play. You can find the thread here:
https://droidchina.com/forum/Thread-First-8-Core-Tablet-and-it-s-China-made
Tomato T2 tablet uses the same CPU.
http://mikecanex.wordpress.com/2013/11/13/tomato-t2-tablet-gets-a-review/I cannot compare the quality of those. But, software issues can be solved with never firmwares I hope. I was thinking buying one of those.
How is GPS locking performance. Since it has Samsung CPU, it must be faster than MTK CPU tablets. I am not very satisfied with the MTK chips GPS lock longer waiting time.
March 17, 2014 at 9:35 PM #16237s7yler
MemberWay to big
, better go for the 7″ Ulefone U7 Octa Core tablet.March 18, 2014 at 3:38 PM #16245Christopher Chang Peng Yen
ParticipantDo an upgrade of the firmware will provide the correct google play.
However, the GPS cannot be use with application, and it itself is difficult to use.
July 1, 2014 at 12:13 PM #17457Rohan99
MemberThese Chinese tablets are amazing. I know the stigma attached to such gadgets made in China with no big brand names but I really don’t see why that stigma is there. Most of the brand name tablets are made in China and so the generic ones are also good. They are usually of a good hardware build and the price is very reasonable. This 8 core tablet seems very good.
