Elephone P4000 Review – Killer Battery Life for the Cheap
  • #9169
    Today we have lots of smartphones, which have really good specs and everything but one thing still needs an improvement – a battery life. A Chinese smartphone maker Elephone wants to offer a very affordable solution with the P4000 model.
    We wanted to say thank you for Pandawill.com for sending Elephone P4000 for a review.
    Elephone P4000 Review: VIDEO
    Elephone P4000 Review: SPECS
    Display 5″ 720P (HD)
    Processor MTK6735 64bit Quad Core, Mali-T720 GPU
    RAM 2GB
    Camera 2MP Front/13MP
    Connectivity Bluetooth, 3G, 4G, GPS, WIFI, GSM,EDGE, GPRS, UMTS, HSPA, HSPA+
    Battery 4.400 mAh (non-removable)
    Dimensions 14.32 x 7.25 x 0.96 cm / 5.63 x 2.85 x 0.38 inches / 168g
    OS Android 5.1
    Storage 16GB (expandable via microSD card slot up to 64GB)
    Elephone P4000 Review: UNBOXING
    IMG_2144
    IMG_2145
    Finally, we’ve come to the star of the show as the Elephone P4000 sports a non-removable 4600Ah battery, which lasts forever and it’s not easy to kill it in one day doesn’t matter what you do.
    The standby times are very good as I’ve used the device for 6 days with more than 6 hours of screen-on time and there were still some juice left.
    With a lighter use, you may even get 8 hours of screen-on time, which is really impressive for a budget phone.
    Elephone P4000 Review: CONCLUSIONS
    IMG_2153
    Elephone P4000 is a device that has been made with one clear selling point – the amazing battery. After testing it out for more than a week I can assure that it delivers and this is the longest lasting budget smartphone, which costs just below $130, by the way, I’ve tested to date.
    IMG_2169
    Also, the Elephone P4000 has a decent 5” screen, good overall performance if you are not a heavy gamer, of course. In addition, the phone has a dual-SIM card slots and one of them even supports 4G. Also, you can easily expand the storage via the microSD card slot.
    IMG_2181
    However, Elephone needed to make quite a few compromises to make a phone this cheap. The camera does not impress at all, the loudspeaker could be better but most importantly the call quality is poor. Well, you can still make conversations but keep in mind that they would not be loud and clear via the earpiece.
    Finally, the Elephone P4000 is a device for those, who want a very cheap phone with a killer battery life but accepts a few important compromises for the sake of the low price.
    We wanted to say thank you to Pandawill.com for sending Elephone P4000 for a review. Gizmo china readers are getting a special $20 DISCOUNT for a limited time! Coupon Code: PWP4000. Expiration date: 09/12/2015
    Buy Elephone P4000 from Pandawill for just $109.99 using a COUPON CODE PWP4000
