Elephone recently unveiled the new Elephone P5000 with a massive 5350mAh battery. Now, the same company is all set to release a phone will global network connectivity and a large battery.
Earlier today, the specifications of the Elephone P4000 model were leaked online. The phone is said to come with the new MT6735 64-bit quad-core processor. The highlight of this chip is its full network connectivity, which should definitely attract some user attention. Another big feature of the new Elephone P4000 is its massive battery. Similar to the P5000, this particular model will feature a 4800mAh high-density battery. Further, it will be equipped with Quick Charge technology to make sure that you don’t have to wait for more than a few hours to charge the device completely.
Other tech specs of the device are pretty decent. The Elephone P4000 is said to come with a compact 5-inch display with 720p resolution. There will be 1GB RAM on board along with 8GB of internal storage. Finally, a 13MP camera unit will be located at the back. The phone is said to run on the new Android 5.0 Lollipop OS right out of the box.
Since MT6735 supports full network connectivity, you can use this phone on practically any network. These are the supported connectivity options: Cat. 4 LTE (FDD & TDD), DC-HSPA +, TD-SCDMA, CDMA2000 1x / EVDO Rev. A and EDGE network.
As for the price tag, Elephone is known for its affordable phones, so expect the P4000 to retail for less than 1000 Yuan ($161). The phone is scheduled to release in May.
