Elephone P2000
- This topic has 0 replies, 1 voice, and was last updated 12 years, 3 months ago by .
Elephone is going to release P2000. It sports MediaTek MT6592-1.7 GHZ Octa-Core processor, 2G of RAM and 16G of ROM and Android OS, 4.4 (Kitkat) with (MIUI OS option). With all these awesome configurations, you will be able to run huge games and as many Apps you desire. If you like selfie, you would definitely love P2000, because its 720*1080P 5.5” HD IPS display, 13MP back camera and 8MP front camera.
Fingerprint identification:
The fingerprint scanner is underneath the rear camera. Guys don’t need to worry about your girlfriends checking your phone from now on. Just remember don’t tell them P2000 actually is able to save three fingerprints for people you trust and they are able to open it. P2000 will help you organize your wallet, because of NFC (Near field communication), which you can use it to shop and pay transportation; sharing files, wireless charging and checking on work attendance. And the combination of fingerprint ID and NFC will let you rest assured.
Hardware:
The hardware make P2000 stand out. Mind blowing 1,7 GHz Octa-core CPU and 2GB RAM allow you to run all apps smoothly. There is 16GB internal storage and micro SD card (capacity up to 128G) for you to build your app collection. And the OGS full lamination screen decrease the thickness by 20% and transparency is increased by 10%. Thanks to OGS, the thickness is just 8.0mm, other dimensions are L154*W78mm.
Connection:
P2000 supports 3G( Double WCDMA; WCDMA/GSM).
HSUPA 5.76 Mbps/HSDPA 7.2 Mbps. Bluetooth 4.0 and GPS+AGPS Navigator. Dual SIM cards and dual standby.
Sensors:
Gravity sensor, proximity sensor, gyroscope sensor, light sensor.
Design:
There are three colors, black, yellow and white. The rubber-like back cover feels excellent. You’ll feel the quality when you’re it. Futuristic design and simplicity make P2000 look elegant, inside and out. Best of all, its suggest retail price is $199. Besides, customers will get upgrade ROM and customized MIUI system.
For more information, please go to our Official http://www.elephone.hk
