Elephone G6 – 5.0″ IPS screen, MT6592 1.7GHz with fingerprint scanner
  • #7496
    s7yler
    UNBOXING
    [video=youtube]http://www.youtube.com/watch?v=qLG2aVfo13M[/video]
    FULL REVIEW
    [video=youtube]http://www.youtube.com/watch?v=vTTp1GWlFGw[/video]
    Camera samples:
    http://plus.google.com/photos/+s7yler/albums/6082341183852604913?authkey=CMzt_P3wl8PTgAE
    Can be found here:
    http://www.efox-shop.com/elephone-g6-mt6592-17ghz-octa-core-5-zoll-hd-ogs-bildschirm-android-44-3g-smartphone-g-296352
    Elephone G6 – Beyond your imagination with 5.0″ IPS screen, MT6592 1.7GHz with fingerprint scanner
    With ergonomic design, the radian on the phone back can perfectly fit for the shape of the palm of your hand, furthermore, the skin-touch material bring you comfortable hand feeling. 5.0″ IPS screen,1280*720 pixels, ppi=293, the parameter configuration is the good basis of amazing visuing effects, we especially did many alignments for the display.
    Built in MT6592 cpu, the frequency has reach to 1.7GHz, with Mali-450 MP4 700MHz GPU. Powerful performance make it easy to deal with any app in your daily using, with low power consumption as the same time. Advanced camera with 13 million pixels, f/2.2 larger light-sensing surface area faster focusing speed and higher focusing accuracy, all those improvement will you better photo experience.
    G6 is equipped with a fingerprint scanner, which could be used for locking screen or set encipherment protection for apps, that can guard your privacy. Double tab the screen to wake it up; and set your customized gesture as short cut to open certain function when the screen is off.
    Highlights
    – 5.0 inch HD IPS, 1280*720 pixels
    – MTK6592 1.7GHz Octa-core
    – 1GB RAM + 8 GB ROM
    – 13MP rear camera + 2MP front camera
    – Standard SIM card + micro SIM card, dual standby
    – Android OS, 4.4.2 KitKat
    – Support 3G Network: GSM 850/900/1800/1900, WCDMA 850/1900/2100 MHz
    – Support Fingerprint ID, Gesture Recognition, GPS, OTG, etc.
