Smartphones have become media consumption devices for most users. For that reason, the bigger the display, the better. Here is where Doogee Y6 Max 3D comes in. As its name suggests, you can experience the 3D and real VR world freely without the need for special glasses. This is called active 3D.
How does the 3D work on Doogee Y6 Max 3D
Due to the Active 3D cylindrical grating LCD screen, the eyes see is two different scenes at the same time. So the mind produces depth image with parallax stereo effect. The subject pops out of the screen and virtually floats in space in front of your eyes when you are watching the video. Its biggest advantage is its brightness is not affected. In addition, its front camera is capturing people’s eyes. And the device customizes and generates the appropriate visual images according to your eye placement.
The innovation in creating the solution took place when the vision chip was added to the GPU. This enhances the rendering speed of the 3D images through the integration of the 3D algorithm, fully resolving the issue of the slow calculation that took place when reproducing complex images. What’s more, the consumption of battery is not affected.
Doogee Y6 Max 3D specs
1. 6.5″ FHD AU Optronics G+FF 1920*1080, 2.5D glass display
2. 3GB/32GB, external memory expandable up to 128GB
3. 4.300mAh battery, 5V2A
4. Samsung S5K3L8 13.0MP, with PDAF
5. MT6750T 64-Bit Octa core
6. Android 6.0
7. Fingerprint sensor, back
8. Silver/Gold
9. HALL sensor
As for its price, Doogee Y6 Max 3D will cost about $150 and it will be on preorder soon. We should mention that there are two version of Y6 MAX, one of which is non-3D and the other is 3D.
