Doogee F1 Turbo Mini (MT6732 + 4G LTE) now available for $125.99
  • #7815
    doogee f1 turbo mini
    Doogee’s compact smartphone, the Doogee F1 Turbo Mini is finally available for purchase. The device features a compact and slim form factor with decent specifications, which makes it an ideal smartphone as your daily driver.
    The phone comes with 64-bit Mediatek MT6732 quad-core processor clocked at 1.5GHz with 1GB ROM and 8GB internal memory which can be further expanded up to 64GB. At the front, there is a qHD 960 x 540 pixel resolution 4.5-inch display. For camera, you have a 8MP rear shooter and a 5MP front shooter.
    Despite its budget placement, the device is quite slim and well designed. At 112 grams, its quite light too.
    However, the highlight of the device is the 4G LTE support over a wide range of frequencies at a very cheap price. Doogee F1 turbo mini will support FDD-LTE Band 1/3/7/20(B1:2100,B3:1800,B7:2600,B20:800MHz)
    WCDMA 850/900/1900/2100MHz & GSM850/900/1800/1900MHz, which means almost every country is supported. This allows for a maximum download speed of 150Mbps and uplink of 50MBPS.
    Like all Doogee devices, the phone comes with a number of smart software features such as Smart gestures, Wake Gesture, 3 finger fast screenshot,  APP blocking, Guest account, Ultra effective power saving mode, Hotknot and PIP mode.
    All these features are available for an impressive price tag of $125.99. This turns out to be a great deal considering 64-bit MT6732 and 4G LTE network support.
