Doogee DG900 Come With 16MP Camera and Rear Touch Panel
- This topic has 0 replies, 1 voice, and was last updated 12 years ago by .
The Doogee DG900 is one of Doogee’s newest releases. Among its features is its rear touch panel which can be used to take photos and a wake gesture function and a 16MP Sony camera. It uses Gorilla Glass 3 glass on both side of the body.
Regarding the Doogee DG900’s design, its measurements are 143 x 72.6 x 7.1mm(L×W×H)and is available in sandstone black and babyskin white. It sports a 5.0” IPS screen with FHD 1080 x 1920 resolution and OGS Full Lamination Technology. Its rear camera is a 16MP Sony IMX135 camera with 5P lens while its front camera is an 88 degree wide angle camera with 8MP and True LED Flash. Users can take big group selfies with this camera. It also supports instant beauty enhancement.
Its processor is the MT6592 octa-core chipset with 1.7GHz. It supports WCDMA 850/2100& GSM850/900/1800/1900. It also supports dual-SIM, ordinary SIM cards, and Micro SIM cards. Its OS is the Android 4.4. Doogee DG900 also has GPS and A-GPS. It does not support NFC but supports OTG, OTA, FM Radio, Bluetooth (BT4.0), and HotKnot. It also has a light sensor, G-sensor, P-sensor, movement-recognition, and back touch. Its speaker is a 1511 speaker made by AAC.
As for memory, Doogee DG900 has 2GB RAM and 16GB ROM with 6.3GB useable memory. It also supports Micro SD cards (T-Flash card) up to 64GB.
Doogee DG900 also supports WCDMA 3G (HSDPA 21Mbps, HSUPA 5.76Mbps) and WiFI hotspots,EDGE, GPRS, EGSM, and WAP. Other features include Flip to Mute, Easy Dial, Easy Answer, and Gesture Answer. To access the Wake Gesture feature, just double tap the screen. It also supports APP encryption.
This phone is powered by a 2500mAh battery and its talk time is 360 minutes while its standby time is 120 hours. Regarding the charger, its input is 100-240V while its output is 5V-1000mA. It uses a USB 5Pin Micro connector and has a 3.5mm earphone jack.
