Doogee Dagger DG550 is the best seller in our store 1949deal right now, due to Doogee manufacturer, it produced the first batch with android 4.2 Jelly bean OS, so we give you the ROM to let your phone to update Android4.4.2. By the way, Doogee DG550 is in big promotion now, it only takes $158.99 for black and white. Please check the ROM tips below.
Click the ROM to download: http://pan.baidu.com/s/1i3ooF1j
[/URL] Overall Description:
ROM Phone DOOGEE DAGGER DG550- ROM Android 4.4.2
Official ROM DOOGEE DAGGER DG550 Version : DOOGEE_DAGGER_DG550_Android_4.4_20140804 – KOT49H
Gapps include – No Rooted
Language support: Multilanguage
Install ROM:
– Unpack FlashTools, and Click on Flash_tool.exe
– Select a the MT6592_Android_scatter.txt in ROM
– Wait file to be added into Flash Tool
– choose Option->USB Model,click USB Model
–> Choose Option->DA DownLoad All->Speed->High Speed, click High Speed
– Turn off your phone, remove the battery.
– “Press F9 (hit Download button)” OR ” if upgrade ROM Firmware->Upgrade ”
– and connect your phone into the computer via USB data cable.
– The process will start and a red progress bar will appear after color purple, yellow.
– And green circles display
– Finish !
– You can now safely disconnect your phone and turn it on.
Just enjoy the ROM of Doogee DG550, hope you smartphone can bring you more happiness and convenience. More ROM news about smartphone will be published on 1949deal now.
