Do you know the thl w11 monkey king android phone?
Viewing 7 posts - 1 through 7 (of 7 total)
  • #4845
    mingtian00
    thl w11 monkey king this new product adds a lot of practical configuration and functionality,the phones features the Beautiful appearance and light weight,beside the configuration is also regarded as relatively high ,the price is very close to the people, it is worth starting
    #14929
    mingtian00
    the thl w11 monkey king phone also can support dual card dual standby ,more convenient in our daily life
    #14935
    mingtian00
    you maybe like the black version of thl w11 monkey king android phone with the classic color and the mainstream 5.0 inch IPS capacitive touch screen ,using the OGS technology
    http://thlmobilemall.com/thl-w11-c-12.html
    [hr]
    yeah good android phone
    #14940
    mingtian00
    thl w11 monkey king is legend
    #14996
    mingtian00
    thl w11 monkey king can be changed with you
    #15002
    mingtian00
    i like this one
    #15034
    mingtian00
    ThL W11 Monkey King of Basic Information
    Model ThL W11 Monkey King
    Band 2G: GSM 900/1800MHz
    3G: WCDMA 850/2100MHz
    Sim Card Dual SIM Card Dual Standby(one micro-sim card)
    Service Provide Unlocked
    Style Bar
    Color Black
    Shell Material Plastic
    System
    OS Android 4.2.1
    CPU MTK6589T, Cortex A7 quad core, 1.5GHz;
    GPU: PowerVR SGX 544
    ROM 16GB
    RAM 1GB
    Screen
    Display Size 5.0 Inch
    Type IPS, capacitive touch screen, OGS technology
    Resolution 1920 x 1080 pixels, 441 PPI
    Screen Color 16000K Colors
    Support Format
    Ringtones Type Polyphonic/MP3
    Audio File Format MP3/WAV/AMR/AWB
    Video File Format 3GP/MPEG4
    Image File Format JPEG/BMP/GIF/PNG/GIF
    E-book Format TXT/CHM/DOC/HTML
    FM Radio Yes, earphone needed
    Earphone Port 3.5mm
    Card Extend No
