Cubot S600 Review – Beautiful and Affordable
- This topic has 0 replies, 1 voice, and was last updated 10 years, 9 months ago by
January 26, 2016 at 11:10 AM #10121
MemberToday we are looking at affordable yet very nice looking Cubot S600. Is it any good? Find out in our full Cubot S600 review.
Cubot S600 VIDEO REVIEW:
Cubot S600 Review: UNBOXING
Cubot S600 Review: SPECS
Display
5″ 720p (HD)
Processor
Mediatek MT6735, 64-bit, octa-core (up to 1.3GHz)
RAM
2GB
Camera
2MP Front/16MP Back
Connectivity
Bluetooth, 3G, 4G, GPS, WIFI, GSM,EDGE, GPRS, UMTS, HSPA, HSPA+, dual-SIM.
Battery
2.700 mAh (non-removable)
Dimensions
14.650 x 7.130 x 0.750 cm / 5.76 x 2.80 x 0.29 inches
OS
Android 5.1
Storage
16GB (expandable via microSD card slot up 128GB)
Cubot included some nice accessories along with the S600 phone. The contents include a tempered glass screen protector, a nice soft TPU case, a charging plug, USB cable, SIM ejector pin and some documentation.
Cubot S600 Review: DESIGN and DISPLAY
As soon as you pick up the phone, Cubot S600 feels like an expensive flagship device. It uses a high quality metal frame around the device and 2.5D glass on the front and rear.
Also, the phone is compact due to the 5” inches display, which only has 720P resolution but it is a high quality panel. It is bright, vivid, colours look natural and it has exclellent viewing angles.
There is an 8MP selfie shooter and a highly customizable LED light on the front top. The capacitive buttons, which also have a nice backlight, are on the bottom.
The glass back is a ridiculous fingerprint magnet and if you hate all the smudges I suggest you going with the white or gold S600 models.
As far as camera, we have a 16MP Samsung shooter with PDAF and dual LED flash. Right below the camera is a fingerprint scanner. I found it to be very easy to setup and accurate to use. Also, it works straight from the standby mode. However, it could be slightly faster at times.
On the bottom there is just a speaker grill.
The buttons are located on the right, they are also metal-made and have a good tactile response.
The left side is where you can find two micro SIM card slots and a separate slot for the microSD card for storage expansion.
The headset jack is on the top and the micro USB port is on the bottom.
Overall, Cubot S600 sports a great build quality, it is nice to look at and hold in the hand, and it literally looks like an expensive handset. However, I don’t like a glass back as it attracts fingerprints and smudges very quickly.
Cubot S600 Review: UI
Cubot S600 has an embedded 2700mAh battery and it performs well for its capacitiy but it is far from the best. I could get just over 3.5 hours of screen on-time when using auto max. brightness setting.
Cubot S600 Review: CONCLUSIONS
Cubot S600 costs around $130 and although it is not a perfect phone, it is definitely worth the price.
It all starts with a nice looking design and excellent build quality, and the fact that the device is compact and can managed with one hand.
Also, Cubot S600 has a high quality display although it is only 720P, it is very fast and responsive in daily use, the camera performs quite well in good lighting conditions and you can use 2 SIM cards and the microSD card at the same time.
However, the battery capacity could have been slightly bigger, the loudspeaker could be louder and the glass back is a huge fingerprint magnet.
Still, despite a few shortcomings, Cubot S600 is a reasonably priced smartphone that can be recommended and you can check out the product link down in the description if you are interested.
