Coolpad has been lauch the Collpad 7295, this phone is came with 5 inch screen size, but now thee is an upgrade version that’s called as Coolpad MAX 7295, the main different is in the screen size that was upgrade to 5,5 inches.
According to MTKSJ website, the specs is almost the same with 7295 but the new 7295+ has larger screen size, there is 5.5 inches large screen with a resolution of qHD level, while the design is same but the body dimmension is different
This new Coolpad 7296+ will carry a 1.2GHz quad-core processor, and perhaps still using MediaTek MTK6589 chipset, coupled with 1GB of RAM and 4 GB of ROM then also support forĀ 32GB through memory expansion slot, the camera uses the same specifications with former model which has 3 megapixel front-facing camera and 5 megapixel rear camera, the new CoolPad 7295+ is running Android 4.2.2 jelly bean operating systems.
Unfortunately, there is no information about the price and availability.
