Chuwi Hi12 : 12-Inch of Awesomeness With Dual OS Support
  • #10056
    Chuwi, the Chinese device manufacturer is not so widely known but it has launched some of the eye-popping products over the last couple of months which include Chuwi Hi10 and Hi12. The latter is worth considering for anyone who’s looking to buy a new 12-inch tablet anytime soon. Read on to find what is so special about this device.chuwi hi12
    Chuwi Hi12 is a 12-inch tablet featuring an elegant unibody metal design with nicely curved edges. This meticulously designed tablet is capable of running both Android as well as Windows operating system which is the trademark feature of Chuwi Hi series.
    chuwi hi12
    Chuwi Hi12 flaunts a 12-inch display with a resolution of 2160 x 1440 pixels with 3:2 aspect ratio which gives this tablet an edge. The tablet is powered by an Intel X5 Cherry Trail Z8300 processor with clocking speeds up to 1.84GHz along with 500MHz 8th Generation Intel Graphics engine.
    chuwi hi12
    On Chuwi Hi12 you will get 4GB of RAM for flawless and fluid multitasking with lots of storage space in the form of 64GB internal storage which supports expandable storage up to 128GB. The memory expansion feature makes this tablet a must buy for those who want to carry their favorite collection of movies and music on the go.
    chuwi hi12
    As Chuwi Hi12 supports dual OS which means that you can get the taste of Android 5.1 Lollipop and Windows 10 on the same tablet and efficiently switch between Android and Windows 10 experience.
    As for the connectivity, you will get one USB 2.0 port, one USB 3.0 port and Micro USB support as well.
    chuwi hi12
    In terms of optics, Chuwi Hi12 features a 5MP rear camera with 2MP front-facing camera which in fact is a little bit disappointing. Had Chuwi bumped the camera resolutions a little more it would have been the best tablet out there. But camera has never been the selling point of Chuwi products so far.
    Chuwi Hi12 is fueled by a massive 11,000mAh battery which will push it through the day with moderate to high usage. It is available in two color tones – Champagne Gold and Space Gray.
    chuwi hi12
    If you can ignore the camera megapixels then this tablet is really promising with its dual OS booting support and huge battery as well as good looks. This tablet carries a price tag of $249 (1642 Yuan) which makes it a worthy competitor and a fierce rival to all other similarly priced tablets in the market.
    You can pre-order the tablet now at $249.
