In this day and age we have smartphones and other gadgets with constantly improving specs and performance. However, there is one know issue – the battery life. Indeed, it is improving with some hardware and software optimisations there and there. Still, the root cause, which is the battery technology itself seems to remain unchanged. The only thing that manufacturers are left with is increasing the battery capacity.
It seems that one of those manufacturers is the Chilli Peppers as their new Peppers 9 device just went through the TENNA certification stage.
It turns out that the new Peppers 9 device will carry a huge 4700mAh battery, which will be one of the highlight features. As far as design goes, the front looks a bit similar to the Nubia devices line (seems to be a quite popular source of inspiration for a variety of Chinese manufacturers). The sides of the phone look to be surrounded by a metal frame and the back of the device is made out of plastic material. The dimensions of the device are 144.8 × 71 × 10.6 (mm) and it has the Weight of 160g.
The handset is equipped with a 5 inch 720P display, it has a MediaTek MT6735 quad-core chip inside along with 2 GB of RAM and 16 GB of internal storage (expandable via Micro SD card slot up to 64GB). What is more, the device 8MP/2MP camera combo on the back and the front, respectively. Also, the Android 5.0 Lolipop is promised out of the box.
Well, the specs sheet is not impressive at all, but given the fact that the device does not carry a powerful chip and the display is not pixel hungry, we should definitely see some outstanding battery performance out of the Chilli Peppers 9 smartphone.
We will keep you updated as soon as the device is released and will provide you with all the relevant news on it, so stay tuned.
