ChangHong is the one of electronic manufacturer from China and now they also entering smartphone market, on last September, Changhong has unveiled their HoPhone Z9/Z9S, the phones is comes with large battery capacity.
And now they unveiled their new smartphone that upgrade version from the Z9S, the new model is ChangHong Honphone Z9H, this phone is also called as Z9 Extreme Edition.
The new ChangHong HonPhone Z9H is comes with 1,7GHz MT6592 processor, replace the previous processor that only has 1,2GHz with MT6589T. Z9H is also supports for TD-SCDMA + WCDMA dual 3G network compatible with China Mobile / China Unicom 2G network. And the interesting is the HonPhone Z9H is poweredby 5,000 mAh battery capacity.
The phone is packs with 5.5-inch HD screen size, support for 13 megapixel camera and custom operating system, the phone is also support for USB-OTG function, gravity sensor, distance sensor and other common light sensor.
The ChangHong HonPhone Z9H is offers with 2,499 yuan or around $400 USD, and this package is comes with USB OTG cable and 10,000 mAh battery packs as separate extra power.
