Hi
I am going to China, guangzhou next week.
I want to buy a phone of minimum 5 inches. 5+ or 6 even better.
Price cannot be more than 1500 yuan.
Anybody can suggest the phones to consider.
thank you
It really depends just what you’re after as there are so many on the market. If you’re after a phone with a 5″+ or even 6″ inch screen then I’d recommend checking out a tablet or even maybe more of a tablet/phone hybrid model.
I believe most of the phones with 5 or plus screen size are very expensive, which are more than 1500 yuan. I have gone to China this year and went to the mobile store. The cheapest phone was about $1400, but the screen size of the phone was about 4. I would recommend you check out some of the Huawei phones, which are on the less expensive side.
There are many phones that meet your request. here I suggest you 3 models found on tinytrade.com: THL W200(5″, $193.99), ZOPO ZP950+(5.7″, $239.99), UMI X2(5″, $239.99). Search reviews on these three phones, you will find that they are of pretty good quality. Hope this will help you!
