Blackview BV6000S launching on July 28th
- This topic has 0 replies, 1 voice, and was last updated 10 years, 3 months ago by .
Blackview BV6000 was released about 2 months ago and it brought a super rugged device at a very affordable price to the market. The IP68 certified smartphone also brought high-end specs to a market that usually offers good protection but with mediocre specs. Now, it is time for another device of the series to be released: The Blackview BV6000S.
The smaller sibling of the BV6000 comes with the same IP68 certification that allows you to submerge the device deeper than 1m as it is considered water-proof and also dust-proof. This doesn’t mean that you should take it with you while scuba-diving as it isn’t guaranteed that it will withstand too much pressure in great depths but it is good enough for regular dives.
On the hardware side, it comes with a bit worse specs that its predecessor but it is no slouch either. It is equipped with MT6735A 1.3Ghz Quad-core instead of the Helio P10 SoC and 2GB RAM instead of 3GB. There is also a reduction in MP size of both cameras as they now offer 8MP/2MP rear/front combination. All other specs remain the same except for the price that is $50 less. For $149.99 you can now preorder the device at Aliexpress. Below you can see the full specs of the device.
| CPU | MT6735A 1.3Ghz Quad-core |
| GPU | Mali T720 |
| Memory | 2GB RAM + 16GB ROM |
| Display | 4.7″ HD 720*1280 |
| OS | Android 6.0 |
| Camera | 2.0MP front camera 8.0MP rear camera |
| Network | 2G: GSM 850/900/1800/1900 3G: WCDMA 850/900/1900/2100 4G: LTE 800/900/1800/2100/2600 |
| SIM card | Dual SIM card slot Dual standby One talk |
| Sensor | Light Sensor Proximity Sensor Accelerometer Sensor |
| Multi-media | Video MP4, 3Gp, MOV, MKV, AVI, FLV, MPEG Audio FLAC, APE, AC, MKA, OGG, MIDI, M4A, AMR Image JPEG, PNG, GIF, BMP |
| Battery | 4500mAh |
| Fast charging | 5V2A |
| NFC | Support |
| Weight | 247g |
| Dimension | 152.3*81*16.6mm |
| Color options | Sunshine Yellow Violet Black Army Green |
