Chinese manufacturers are on a streak when it comes to updating to Android Nougat. Several models will receive OTA updates by the end of the year. That said, Blackview BV6000 is next in line. The rugged device from Blackview is on schedule to receive the update in mid-November.
In the mean time, until Android 7 comes, another OTA is on its way to improve some bugs. The update is due tomorrow and the improvements it brings are as follow.
- No notification will show up about the device being rooted when installing certain applications
- The max volume of the recorded videos has been optimized to be louder and clearer
- Corrected a language mistake of the Russian translation in UI
Blackview BV6000 Main Features
SoC: MT6755 Octa-core 2.0 GHz – T860 GPU
RAM/Storage: 3GB+32GB (upgradable up to 32GB via microSD)
OS: Android 6.0
Display: 4.7 inch HDips 720*1280
Body Material: CNC metal frame
Network: 2G: GSM 850 / 900 / 1800 / 1900
3G: WCDMA 900 / 1900 / 2100
4G: FDD-LTE 800 / 1800 / 2100 / 2600
Battery: 4,500mAh
Camera: 5.0MP OV5670 85°wide angle front camera, 13.0MP OV rear camera, F2.0
Other: IP68 Certification
